Trying out the newest version of Webmin on an Ubuntu 64 OS, and Apache is driving me nuts. I removed the 1st virtual domain which I guess is the default var/www folder, and apache wont start up, says it looks for the file that is suppose to tell it the list of sites , and its either no longer there, or its not readable. This is the second time I had this problem, and the first time, I tried to reinstall apache at the comand prompt, and it created more problems. Removing the module from webmin modules will keep the virtual zones in there when you re-install, so its not really like a fresh start f you make a mistake. I wound up reinstalling webmin, after doing a purge of everything…and then I recreated this same problem when I deleted the virtual host setting for the var/www folder. It seems you cant get around not having that zone active, but it will let you delete it without a warning…and I guess the module delete function dont ask you if you want to start over or not. I thought I could remove that one because if I type: http://ipaddressofserver , whatever is in that folder will show up, and at times the site I was working on setting up was the only one coming up when I called paths to different folders from that url.
I also have problems with postfix and sendmail and fetchmail…seems I cant get any of them to connect together to actually fetch the mail for my single email user.
I used Virtualmin/ Webmin almost 2 years ago, and was hit with some kind of script attack that caused pages to become blank…so I ditched it. Later I was told that it may have been because the host provider did not do all their updates. I never really found out how it got there, but thought I would try it now and test the waters again. I dont remember it being this complex though the last time, but back then I had someone helping me that did most the setup. Is there a sequence to follow when you set up the mail systems and domains in apache? I noticed some modules depend on apache, and at times more then one mail program got installed, how, I dont know…
Well, you should be able to remove that first domain in Ubuntu, so there may be something about the way you’re removing it that’s causing trouble. If you want to talk about that, we can certainly go over how you’re removing that, and see if there’s any reason why that’s not working properly.
However, another way to solve this particular problem would be to choose a domain you want to act as your default domain – and then we can tell Virtualmin to always load it, and not that first domain in Apache – to load whenever accessing the server by IP address.
To do that, just go into Server Configuration -> Website Options, and set “Default website for IP address”.
I wound up purging, then re-installing apache2 for the 2nd time via the command prompt in ssh. It rebuilt the file 000-default under sites enabled folder in apache2. Doing a regular Webmin module remove for apache, then reinstalling , wont rebuild that file, or it causes a syntax error inside it I think…at least thats what it says when you try to restart apache from Webmin. When you reinstall that apache module, it actualy does not remove anything under the sites enabled folder. I think it may be a good idea for a newer version of the module to ask weather or not to keep them, or remove the sites currently enabled.
I had another problem because my ftp session didnt upload all the files needed for one of the var/www domains…and that took a while before I could figure it out, but with the new 000-default file in there, that is basicly the var/www main index folder, and I cant see a way to get the other domains I have in that folder to
load without having that initial virtual 000-default in there. It may be because right now, I am not using a dns to resolve all my domains…I am merely testing via http://serveripaddress/whateverdomain , to make sure all the files are good, and that the mysql system is able to connect - etc. Last night I had the sql working, but seems now that I have removed apache2, it took out the installation of phpmyadmin along with it, so will need to re-install that too.
Definately I will need help with the postfix / sendmail / fetchmail stuff…
Ok, looks like I got the apache2 stuff under control. What I dont understand now is the mail. I have setup mail before with other panels like cpanel / plesk, but something seems to have glitched. I have previous past experience not so great with Qmail, so I elected postfix. Seems we also need fetchmail, so I included that module. Do we need sendmail too? I would think no because if I check the ports I get:
lsof -i :110
lsof -i :25
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
master 29583 root 12u IPv4 172075 0t0 TCP *:smtp (LISTEN)
So 25 smtp is listening, however seems my pop / 110 port is dead. At one point I had the system accepting the mail but fetchmail would not deliver. Do I need to set up the mail.domain.com over in the bind dns server under each domain I put there? I do have one domain actually set up with a resolving DNS to the site itself, and apache will load it fine, and its mail.domain.com addy resolves to the IP of the server, but when it goes to connect, is says there is no socket, which I guess it because there is nothing listening on port 110. Can anyone help? I did notice at one point sendmail would no longer start, and supplied no error messages, so I removed it as a module…at one point I tried Exim, but its no longer showing up anywhere as a remove or an install possibility. I lije the fact you can switch between all these mail clients. Back in plesk you are stuck with Qmail, and its terrible.
How did you install Virtualmin onto your system? Did you use the install.sh installer?
The issues you’re running into are uncommon – normally when using the install.sh to perform an installation, you’d end up with Apache and Postfix working out of the box, as well as Dovecot which runs on ports 110 and 143.
If you didn’t use the install.sh to perform your installation, that means you have a lot of manual work ahead of you
Also, which version of Ubuntu is it that you’re using there? Virtualmin only supports the Ubuntu LTS releases, the latest of which is 10.04.
So if you hadn’t used the install.sh script, my recommendation would be to start with a fresh installation of Ubuntu 10.04, and use the install.sh script to get Virtualmin up and running.
You should, in theory, end up with a fully working system out of the box
Once you do get things up and running – although you can use other mail servers, it’s not recommended that you use anything but Postfix… it’s well supported, and it’s easy to get help if anything does happen to go wrong.
Regarding port 110 – you may want to try launching dovecot though, as that’s the service that normally runs on that port. You can launch it with this command:
This is the 2nd install of Virtualmin - the first time was the hosting company that installed it, not sure how they did it.When it broke down, I googled for reinstalling , followed the instructions from the command prompt, and scrolled back to my commands to reinstall apache2 from when I encountered problems on the first Vm instaled system. I do not ever remember dovecot being installed at any point by default. Is it a dependent module for postfix?
Here are some of the commands I entered when installing webmin for the2nd time:
…which executed from that folder, seemed to install without any problems.
I do recall apache in there as the default, however there was a setup page for the mail where I had to select which system from a drop down box I wanted to use. Options were postfix, exim and I think qmail and some others. At one point it was letting me set exim when it was not installed, but I do remember installing it. Perhaps there ought to be some troubleshooting the team could do regarding that interface someday, because it does not seem you can dynamicly swap from different mail systems if in your configuring, the one you are working with does not work for some reason - seems there was a problem that propogated itself into making no mail client work, save for maybe qmail, which I dont want to try because I have had problems with it before.
Reading package lists…
Building dependency tree…
Reading state information…
The following packages were automatically installed and are no longer required:
m4 procmail sendmail-cf sendmail-base libdb4.7
Use ‘apt-get autoremove’ to remove them.
Suggested packages:
ntp
The following NEW packages will be installed:
dovecot-common dovecot-imapd dovecot-pop3d
0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
Need to get 7805kB of archives.
After this operation, 15.7MB of additional disk space will be used.
Get:1 http://us.archive.ubuntu.com/ubuntu/ lucid-updates/main dovecot-common 1:1.2.9-1ubuntu6.5 [5510kB]
Get:2 http://us.archive.ubuntu.com/ubuntu/ lucid-updates/main dovecot-imapd 1:1.2.9-1ubuntu6.5 [1202kB]
Get:3 http://us.archive.ubuntu.com/ubuntu/ lucid-updates/main dovecot-pop3d 1:1.2.9-1ubuntu6.5 [1093kB]
Fetched 7805kB in 3s (2582kB/s)
Selecting previously deselected package dovecot-common.
(Reading database … 71051 files and directories currently installed.)
Unpacking dovecot-common (from …/dovecot-common_1%3a1.2.9-1ubuntu6.5_amd64.deb) …
Selecting previously deselected package dovecot-imapd.
Unpacking dovecot-imapd (from …/dovecot-imapd_1%3a1.2.9-1ubuntu6.5_amd64.deb) …
Selecting previously deselected package dovecot-pop3d.
Unpacking dovecot-pop3d (from …/dovecot-pop3d_1%3a1.2.9-1ubuntu6.5_amd64.deb) …
Processing triggers for ufw …
Processing triggers for ureadahead …
Processing triggers for man-db …
Setting up dovecot-common (1:1.2.9-1ubuntu6.5) …
Creating config file /etc/dovecot/dovecot.conf with new version
Creating config file /etc/dovecot/dovecot-ldap.conf with new version
Creating config file /etc/dovecot/dovecot-sql.conf with new version
adduser: Warning: The home directory `/usr/lib/dovecot’ does not belong to the user you are currently creating.
Creating generic self-signed certificate: /etc/ssl/certs/dovecot.pem
(replace with hand-crafted or authorized one if needed).
hostname: Name or service not known
dpkg: error processing dovecot-common (–configure):
subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of dovecot-imapd:
dovecot-imapd depends on dovecot-common (= 1:1.2.9-1ubuntu6.5); however:
Package dovecot-common is not configured yet.
dpkg: error processing dovecot-imapd (–configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of dovecot-pop3d:
dovecot-pop3d depends on dovecot-common (= 1:1.2.9-1ubuntu6.5); however:
dpkg: error processing dovecot-pop3d (–configure):
No apport report written because the error message indicates its a followup error from a previous failure.
dovecot-common
dovecot-imapd
dovecot-pop3d
E: Sub-process /usr/bin/dpkg returned an error code (1)
… install failed!
But I can see it in the servers area, however it wont start:
(Error: ssl_cert_file: Can’t use /etc/ssl/certs/dovecot.pem: No such file or directory
Fatal: Invalid configuration in /etc/dovecot/dovecot.conf)
Nope! It’s not a dependency of Postfix, they’re considered separate by Ubuntu, since there are a variety of POP/IMAP services you could use. However, Virtualmin makes use of Dovecot.
When installing Virtualmin via the install.sh – that would pull in all the services such as Postfix, Dovecot, MySQL, Apache, SpamAssassin, ClamAV, and such, and it will also configure them to work properly.
When not using the install.sh, that’s a manual installation – it’s a lot more work, but it can still be done. Directions for a manual installation are here:
I’d highly recommend using a fresh distribution install, and using the install.sh script. However, if you’d like to try to continue with what you have, the above should help.
Also just tried installing Dovecot , failed !
Well, I see this error in there:
Dovecot requires that “hostname -f” return an FQDN in order for it to install properly. You may want to review what your hostname is, and make sure that hostname -f is returning an FQDN.
Ok, I fixed the hostname -f problem, somehow it had kept part of the old hostname alongside of the new one…and never prompted me to change the option -f part.
Rebooted, and now its listening on the port fine. However any mail sent to the test address gives a relaying error. Also when checking mail, its saying text logins are disallowed. Searched google for that, and saw where in the dovecot conf, that is the default setting. I found 2 config files with that setting = yes, and I changed to = no, but its still giving that message during the login. Rebooted again just to check, and same thing…? Also of note, during the server test for the fetchmail, its saying the mailserver does not equal the address [ fetchmail: Server CommonName mismatch]. I had it as same as server name, and then the actual IP addy of the server and same thing. The domain itself resolves to the server in dns checks…but the name I am using for the hostname is my old servername which has a domain that is still hosted on my old server I am moving from…is that a problem?
If you wish to continue with the manual installation, I’d definitely prepare yourself for a lot of tinkering and troubleshooting
However, if you haven’t already, you’d want to go through the manual installation guide mentioned above, and perform all the configuration mentioned in it.
Yeah, that’s something the Virtualmin installer would normally correct in the dovecot config – you’d need to make sure that “disable_plaintext_auth = no” is set in your /etc/dovecot/dovecot.conf file, and then restart Dovecot afterwards with “/etc/init.d/dovecot restart”.
If you continue to get that error, it sounds like that option is still set somewhere within the Dovecot config.
Were you performing your test using SSL or TLS? That may be a SSL/TLS error, as it may have been comparing the hostname you used to connect, versus the hostname set in the SSL certificate.
Ok, I added the disable_plaintext_auth = no to that file you pointed out, still same problem. That option also was in 2 other config files where I used the file manager search to locate before I did this, and thats where I had also changed that, but still, after doing this, and restarting Dovecot, same thing.
I noticed this file used the brakets { } system, which means there is actual code executing there. I merely placed that line as you pasted, not sure if it has to bein brackets? Because in my fumbling about last night, I came accross a post where someone said you can allow your specific ip address where you log in from such as xx.xx.0.0/16 and the disable_plaintext_auth = no would be valid for just that address range. Could I try that here in the file you pointed out? I cant find the article I was looking at last night anymore in my history…
Oh, and that test was the fetchmail ’ test server ’ button, where you can test the server you enter for the fetchmail to execute.
Ok seems disable_plaintext_auth is in lots of files according to the built in search with file manager. I thought there was maybe 3 but theres more. Still getting that same error.
When I first set up the mail, there was kind of like a universal setup page where I could select the kind of system - IE: postfix, Exim , qmail - etc. There was an option for auto detect too. But I cant seem to find this page anymore in the webmin menu? Does the system really work when you switch around from different mail systems, removing and reinstalling them? So far to me seems like there are some problems with that.
You may want to log in over SSH, and manually review the Dovecot config files to try and understand what’s going on there.
However, it normally only takes modifying one line in order to get Dovecot to work using the plain text authentication.
No, it’s not really designed to work that way… if you switch from one mail server to another, your current mail server settings, email addresses, aliases, and the like would all be lost.
That screen is there so that, when things are first setup, you can tell it what mail server would be used – and it would use that information so that it understands how to add email related information to the system. But it’s not possible to convert from one system to another.
We’d highly recommend using Postfix.
I can’t help but notice though that you’ve been working on getting your manual installation up and running since Sunday. And you probably still have a lot of work to go.
However, were you to start over, perform a fresh install of Ubuntu 10.04, and use the install.sh script to perform the Virtualmin installation (available in the Downloads link above), you could have this all working in an hour or two
Yes, and thanks for all your help. I was thinking of the reinstall last night.
However, I have got the websites all uploaded and working with apache, and also I installed phpmyadmin, and got it to work with the 2 sites that need sql to operate. It was not easy and one site has quite a large db that meant I had to change the max upload file size to get it to upload. Would I be able to save these settings and sql data locally on the server and still do theinstall.sh you describe ? It seems a waste to have worked on some things, got them all going that are suppose to be more difficult than just the email. I still think this entire problem ought to be investigated by the team for a possible fix in newer versions. It was really easy to break the email installation or misconfigure it. All other panels I have used, never had such a problem like this.
Well, I think your view of how Virtualmin works would be different had you used the automated installer.
Anything else, and you’re not getting the designed setup. So, there’s nothing we could really fix, you’re not getting what was intended since you’re performing the installation manually
That said, we do recommend using the default Postfix mail server.
That’s difficult to say, I’m not entirely certain what all you did to achieve the setup you have now. On a typical Virtualmin installation, you would just go into Backup and Restore -> Backup Virtual Servers, and you could generate a backup of all the domains you have configured now, and then restore them later after performing a fresh installation.
However, since you have a non-standard manual installation, I don’t understand enough about what you have going on there to assist in that process.
Ok, I guess theres not much else to do. My hosting provider did the first install, so I will ask them if they used the install.sh script the first time. I will have them do a nuke of everything, install Ubuntu fresh , then post here for some more suport.
Ok all set. Fresh install of Ubuntu. Where do I go from here? Will we install as the user or as root? I believe the only root login I can do is the su root…
Also, is it safe to do any OS updates now before we start with the webmin install, or do we wait until webimin is installed, then do updates?
Ok, so we begin with virtualmin? The first time, the hosting company had installed webmin, and from within that I could install virtualmin…now kinda confused. That link you supplied seems to say that Ubuntu will have to use the manual install…? The support guy on the server did tell me that they used their own install script for webmin.
That link you supplied seems to say that Ubuntu will have to use the manual install.
Hmm, where do you see that?
You mentioned above that you were using Ubuntu 10.04, which is one of the Grade A supported distros. And as that link mentions, all the Grade A supported distros can use the automated install.sh script.
Well, we don’t recommend using that method to perform the installation, as that’s essentially a manual install, and a lot of things won’t work out of the box.
If you’re using a Grade A supported distro, and you follow the instructions in the link I shared, you should be able to have Virtualmin up and running quickly using the automated installer, and that’ll configure all the various services on your server to work correctly out of the box.
