I looked over the demo and I don’t see any way to monitor the bandwidth. Is there a option thats not enabled? How would the customer know how much bandwidth they were using?
Greg
Greg
Hey Greg,
Yes, Bandwidth Monitoring is supported. It’s just disabled by default. I’ve turned it on, so now it shows up in the left menu pain under Administrative Options: Usage Graph.
If you don’t happen to see it in the next 20 hours or so (when it gets reset with a fresh copy of the system), feel free to turn it back on. It’s under System Settings: Bandwidth Monitoring.
Overages can trigger emails to the domain owner and the administrator. They can also disable an account. All bandwidth and quota triggered events are optional and configurable.
Holler if you have any questions about how to use it. We also take wishes in the bug-tracker, if after you try it out you find that it doesn’t do what you need.
