Hello all
I have a Ubuntu 14.04 VPS server with Virtualmin 4.18.gpl. Everything upgraded, latest today.
I have created many virtual hosts that work perfectly, also subdomains work without any problem.
For one virtual host I need to use Wordpress Network (Wordpress Multisite). And I need an alias domain to point to the parent domain (Wordpress domain) in order to let Wordpress redirect the call to one of the wordpress-networked subdomains.
The nameservers of the alias domain is the nameservers of the above mentioned Ubuntu 14.04 installation, so configured correctly as all other virtual host working on this machine
I am able to create this alias domain from within Virtualmin (keeping default settings), and everything “looks” OK, but this alias domain will not resolve to the parent domain. My internet browser just hangs there forever when I point to the alias domain.
Every test PASSES when I put the alias domain in a tool like http://www.webdnstools.com/dnstools/domain_check, thus telling me that the virtualmin setup and the nameservers are working appearantly as well as any other domain on the server…but still not able to resolve to the parent domain.
I am able to ping all virtual hosts on the server, but not this alias domain, this even if webdnstools.com reporting that the domain works ok…strange.
I have also tried to create this aliasdomain as an alias domain for another virtual host that has only a simple working joomla installation. The alias domain will not resolve to this parent domain either. So for this I conclude that the problem has nothing to do with the WordPress Network (mulitisite) configuration mentioned in the first virtual host.
It seems to me that for some reason I am not able to create a working alias domain at all. I can create it in Virtualmin, but it is not working as it is supposed to do.
I have looked at various logs without finding anything special that could indicate the problem.
Only in apache error.log I found some messages about “libgcc_s.so.1 must be installed for pthread_cancel to work”. I don’t know if this has anything to do with the non working alias domain.
Anyone able to help?
[Sun Sep 06 16:04:16.037173 2015] [mpm_prefork:notice] [pid 14106] AH00171: Graceful restart requested, doing restart
[Sun Sep 06 16:04:16.272638 2015] [auth_digest:notice] [pid 14106] AH01757: generating secret for digest authentication ...
[Sun Sep 06 16:04:16.326647 2015] [ssl:warn] [pid 14106] AH02292: Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Sun Sep 06 16:04:16.329160 2015] [mpm_prefork:notice] [pid 14106] AH00163: Apache/2.4.7 (Ubuntu) SVN/1.8.8 mod_fcgid/2.3.9 PHP/5.5.9-1ubuntu4.11 OpenSSL/1.0.1f configured -- resuming normal operations
[Sun Sep 06 16:04:16.330952 2015] [core:notice] [pid 14106] AH00094: Command line: '/usr/sbin/apache2'
[Sun Sep 06 16:04:55.762474 2015] [mpm_prefork:notice] [pid 14106] AH00171: Graceful restart requested, doing restart
[Sun Sep 06 16:04:55.920937 2015] [auth_digest:notice] [pid 14106] AH01757: generating secret for digest authentication ...
[Sun Sep 06 16:04:55.957552 2015] [ssl:warn] [pid 14106] AH02292: Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Sun Sep 06 16:04:55.957750 2015] [mpm_prefork:notice] [pid 14106] AH00163: Apache/2.4.7 (Ubuntu) SVN/1.8.8 mod_fcgid/2.3.9 PHP/5.5.9-1ubuntu4.11 OpenSSL/1.0.1f configured -- resuming normal operations
[Sun Sep 06 16:04:55.957771 2015] [core:notice] [pid 14106] AH00094: Command line: '/usr/sbin/apache2'
[Sun Sep 06 16:17:54.527790 2015] [mpm_prefork:notice] [pid 14106] AH00169: caught SIGTERM, shutting down
[Sun Sep 06 16:17:55.516619 2015] [ssl:warn] [pid 25555] AH02292: Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Sun Sep 06 16:17:55.518074 2015] [suexec:notice] [pid 25555] AH01232: suEXEC mechanism enabled (wrapper: /usr/lib/apache2/suexec)
[Sun Sep 06 16:17:55.539749 2015] [auth_digest:notice] [pid 25557] AH01757: generating secret for digest authentication ...
[Sun Sep 06 16:17:55.577924 2015] [ssl:warn] [pid 25557] AH02292: Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Sun Sep 06 16:17:55.583112 2015] [mpm_prefork:notice] [pid 25557] AH00163: Apache/2.4.7 (Ubuntu) SVN/1.8.8 mod_fcgid/2.3.9 PHP/5.5.9-1ubuntu4.11 OpenSSL/1.0.1f configured -- resuming normal operations
[Sun Sep 06 16:17:55.584091 2015] [core:notice] [pid 25557] AH00094: Command line: '/usr/sbin/apache2'
[Sun Sep 06 16:17:56.976458 2015] [mpm_prefork:notice] [pid 25557] AH00169: caught SIGTERM, shutting down
[Sun Sep 06 16:17:58.007785 2015] [ssl:warn] [pid 25633] AH02292: Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Sun Sep 06 16:17:58.009879 2015] [suexec:notice] [pid 25633] AH01232: suEXEC mechanism enabled (wrapper: /usr/lib/apache2/suexec)
[Sun Sep 06 16:17:58.032609 2015] [auth_digest:notice] [pid 25634] AH01757: generating secret for digest authentication ...
[Sun Sep 06 16:17:58.059094 2015] [ssl:warn] [pid 25634] AH02292: Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Sun Sep 06 16:17:58.062885 2015] [mpm_prefork:notice] [pid 25634] AH00163: Apache/2.4.7 (Ubuntu) SVN/1.8.8 mod_fcgid/2.3.9 PHP/5.5.9-1ubuntu4.11 OpenSSL/1.0.1f configured -- resuming normal operations
[Sun Sep 06 16:17:58.063422 2015] [core:notice] [pid 25634] AH00094: Command line: '/usr/sbin/apache2'
[Sun Sep 06 16:53:55.381859 2015] [mpm_prefork:notice] [pid 25634] AH00171: Graceful restart requested, doing restart
[Sun Sep 06 16:53:55.594491 2015] [auth_digest:notice] [pid 25634] AH01757: generating secret for digest authentication ...
[Sun Sep 06 16:53:55.677918 2015] [ssl:warn] [pid 25634] AH02292: Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Sun Sep 06 16:53:55.678124 2015] [mpm_prefork:notice] [pid 25634] AH00163: Apache/2.4.7 (Ubuntu) SVN/1.8.8 mod_fcgid/2.3.9 PHP/5.5.9-1ubuntu4.11 OpenSSL/1.0.1f configured -- resuming normal operations
[Sun Sep 06 16:53:55.678145 2015] [core:notice] [pid 25634] AH00094: Command line: '/usr/sbin/apache2'
[Sun Sep 06 17:28:18.457608 2015] [mpm_prefork:notice] [pid 25634] AH00169: caught SIGTERM, shutting down
[Sun Sep 06 17:29:04.919965 2015] [ssl:warn] [pid 2699] AH02292: Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Sun Sep 06 17:29:04.920117 2015] [suexec:notice] [pid 2699] AH01232: suEXEC mechanism enabled (wrapper: /usr/lib/apache2/suexec)
[Sun Sep 06 17:29:04.939719 2015] [auth_digest:notice] [pid 2700] AH01757: generating secret for digest authentication ...
[Sun Sep 06 17:29:05.043580 2015] [ssl:warn] [pid 2700] AH02292: Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Sun Sep 06 17:29:05.051000 2015] [mpm_prefork:notice] [pid 2700] AH00163: Apache/2.4.7 (Ubuntu) SVN/1.8.8 mod_fcgid/2.3.9 PHP/5.5.9-1ubuntu4.11 OpenSSL/1.0.1f configured -- resuming normal operations
[Sun Sep 06 17:29:05.051098 2015] [core:notice] [pid 2700] AH00094: Command line: '/usr/sbin/apache2'
