Failed to start service :
Starting web server: apache2.
The apache is running but we get the following error message when clicking on the green triangle as the system information shows apache as NOT running after the update to 1.640
You should login to webmin interface, then go to Webmin-Webmin settings-Modules and put this link to “download from webmin server”
More info - http://www.webmin.com/updates.html
in virtualmin 4.01gpl version and webmin 1.640
return of my experience with this problem solved after the first as above. (thank you)
in virtualmin the shortcut link :
“virtual-server/start_feature.cgi?feature=web&redirect=/right.cgi”
not run apache, because apache is running :))
the link stop dont active
the icon apache is down or apache is running
my icons apache on virtualmin system information page : up is red and actions is green.
Found my answer right here…
I’ve found so many answers to questions here, if you have posted a problem or responded to one to resolve. A big thanks from me. The community is fantastic.
Failed to start apache :
but actually apache is running already. The only thing what has changed is that I can see now again all virtualservers and other settings on the apache Server module but it asks me to START the server instead to stop it as it is already running!
PLEASE - Don’t let people search again, instead post the solution you actually did:
Webmin -> Servers -> Apache Webserver -> Module Config -> System Configuration : Path to Apache PID file. Set that from “work out automatically” to the actual path and filename of your Apache PID file.
