I’m not sure if I should even do what I want to do, but I’ll let people tell me if I’m doing it wrong.
I’m in Ubuntu server 16.04 LTS with a Virtualmin paid version running on it; let’s call it “web” cause it’s my DMZ. Within my local network, I have another server running similar to the first, but it’s a Webmin only interface, and basically, I’m using it as a MySQL database info server for a project; let’s call it “secret” cause whatever. I’m trying to connect to secret via Virtualmin on web by guess-and-test, but I’m failing.
Inside my network I access secret via phpMyAdmin and all is well. I want a way to access it remotely using the Webmin > Servers > MySQL Database Server module on web. One attempt had resulted in a second menu item for “MySQL Database Server” in the Webmin > Servers menu on web.
My error messages while trying to create it in “Connect to MySQL server” are
- Failed to add MySQL server : Require mysql-192.168.1.114-root/mysql-192.168.1.114-root-lib.pl failed :
- Died at (eval 108) line 1.
If I try to access it in Webmin > Servers on web I just see these error messages
- MySQL is not running on your system - database list could not be retrieved.
- The full MySQL error message was : DBI connect failed : Can't connect to MySQL server on '192.168.1.114' (111)
So, I wonder if the inputs I’m putting in Connect to MySQL Server are badly formatted, or if I’m doing something that won’t work no matter what. I wonder if I should even be trying to give myself remote access by this method in the first place.
