urthllc
December 13, 2021, 4:28pm
1
**OS type and version:Ubuntu 20.4
**Webmin version:1.981
**Virtualmin version: 6.17-3 Pro
**Related products version:
I have a LE Cert and it works for all the websites but I can’t seem to get rid of this error on the primary domain:
ERROR — DOCUMENT FOLLOWS
This web server is running in SSL mode. Try the URL https://urthllc.com:10000/ instead.
Joe
December 13, 2021, 4:32pm
2
That’s not an error you want to get rid of. You’re trying to connect to http
instead of https
. You should connect to https
If you get an error when connecting to https, tell us that error.
urthllc
December 13, 2021, 4:35pm
3
Isn’t it suppose to auto redirect to https? I guess I used the wrong terminology in the title,
I can’t seem to get the auto redirect to work on my paid version. It works fine on a different server with the free version
Joe
December 13, 2021, 4:38pm
4
Nope. It gives a link to the right URL. If that link isn’t right, then it needs to be configured to know the right hostname.
Joe
December 13, 2021, 4:39pm
5
Hm…it doesn’t default to auto-redirecting. Maybe there is a config option for it, if you’ve seen it behave that way elsewhere. I’ll look around…
Joe
December 13, 2021, 4:40pm
6
Yep, it’s configurable: Webmin->Webmin->Webmin Configuration->SSL Configuration->Redirect non-SSL requests to SSL mode?
urthllc
December 13, 2021, 4:48pm
7
Thanks Joe, I knew there was a second place to check mark it. I had done so for the website configurations but couldn’t find the one you mentioned.
Thanks again!!
system
Closed
December 21, 2021, 4:49pm
8
