Actions link settings?
OS type and version Debian 12
Webmin version 2.610
Webserver version Apache version 2.4.65
Related packages WP Workbench Manager
Any way we can get a setting for the Actions buttons to open in current or new tab. Not a big issue, but I’m constantly closing tabs down since they launch a new one with each click.
Did you check the module config? There should be an option to do it.
If not, you can do it with the following command:
sudo sed -i 's/^link_target_new=.*/link_target_new=0/' /etc/webmin/virtualmin-wp-workbench/config
Does it work for you?
This worked well enough @Ilia. The wp admin dashboard opens in a new tab, but at least the manage button uses the same browser tab. I looked at the config and there are 12 variables. Only 10 are listed on the module configuration page. It looks like the following two variables don’t have a gui config component: update=1, link_target_new=0. Adding link target to the module config might help others. It was the first place I looked prior to submitting. Thanks!
Alright, thanks for your suggestion! I’ll fix it in the next WP WB release.
