Access webmin not possible
OS type and version Fedora Linux 41 (Server Edition)
Webmin version 2.02
Hello, i can´t access webmin, the server is not reachable. I have installed it via dnf. Why is my webmin not reachable? i have started the service with “service webmin start”.
Do you have a firewall? Is it installed on a cloud provider that requires explicitly allowing ports (you need port 10000 for the web UI)?
The webmin installed doesn’t open port 10000 in the iptables. You need to do that manually.
https://webmin.com/firewall.html
ohh okay. i try that :grinning:
Do I have to start the cloud provider separately?
No, did it work?
