I’m new to virtualmin/webmin and I just migrated a cpanel server over. I got everything working properly except until I tried to setup thunderbird with imap accounts and I have been trying to fix this for hours.
No matter the config, I could not get a connection. I am able to telnet to dovecot and login that way with no problem. I enabled all the dovecot logging info and here is what I get when trying to connect via thunderbird
dovecot log:
2012-08-06 23:56:38 auth-worker(default): Info: pam(webmaster,-MY.IP-): lookup service=dovecot
2012-08-06 23:56:38 auth-worker(default): Info: pam(webmaster,-MY.IP-): #1/1 style=1 msg=Password:
2012-08-06 23:56:39 auth-worker(default): Info: pam(webmaster,-MY.IP-): pam_authenticate() failed: Authentication failure (password mismatch?) (given password: -MY Entered Password-)
2012-08-06 23:56:41 auth(default): Info: client out: FAIL 2 user=webmaster
2012-08-06 23:56:51 imap-login: Info: Disconnected (auth failed, 2 attempts): user=webmaster@WEBSITE.COM, method=PLAIN, rip=-MY.IP-, lip=69.64.35.123, TLS
The auth log:
Aug 7 00:00:39 web dovecot-auth: pam_unix(dovecot:auth): check pass; user unknown
Aug 7 00:00:39 web dovecot-auth: pam_unix(dovecot:auth): authentication failure; logname= uid=0 euid=0 tty=dovecot ruser=webmaster@WEBSITE.COM rhost=-MY.IP-
I noticed the first line of the auth log says “user unknown”. I am not sure what that is about epically since the second line of ruser has the username
I also noticed that if I telnet in and login, there is no record in the logs.
The next problem is that if I change the password for the user via virtualmin, it is not being updated - at least not for email accounts. How I found out about this is via telnet login. I had to use the old password.
Any suggestions would be greatly appreciated!
Thank you.
