| SYSTEM INFORMATION | |
| OS type and version | REQUIRED |
| Webmin version | REQUIRED |
Hey every one i got this error when i try to run phpmyadmin with my adress ip
Check your logs for a clue, you posted on webmin so I presume you installed manually.
Plus you have not post your system info.
Have you checked the error logs? Does the folder and script exist inside the “public_html” folder for the domain?
Your Nginx logs or error logs. I know very little about Nginx as I’ve always used apache. Is the main site working as I get a timeout.
