I have spent a week or two researching and setting up my server to run Apache with the Worker MPM and FCID. I am trying to optimize it to allow for the most concurrent connections possible. It has been a nightmare to find good info on the Worker MPM.
Server - 1GB RAM (With Apache turned off its only using about 150MB of RAM) I would like Apache to have a memory usage CAP of about 750MB - so that my server will never run out of RAM.
I have been running the server for about 2 years without any problems - but we have recently started streaming MP3`s and this requires more concurrent connections. The server has also had a few minor DDOS attacks - so I trimmed the settings down a ton to prevent the server from running out of memory - I also added some firewall rules to rate limit.
The set up I have now looks like its working well - but I am getting some Segmentation fault errors
[Sat Mar 23 03:19:50 2013] [notice] child pid 28351 exit signal Segmentation fault (11)
[Sat Mar 23 03:56:20 2013] [notice] child pid 29740 exit signal Segmentation fault (11)
*** glibc detected *** /usr/sbin/httpd.worker: malloc(): memory corruption: 0xb83abdd8 ***
And some Out of Memory Errors
Out of memory during array extend.
I am also just afraid that I have trimmed things down too much!
This is my current set up, I would really appreciate some advice.
Apache Settings:
Timeout 30
KeepAlive On
MaxKeepAliveRequests 100
KeepAliveTimeout 2
# Spawn 2 child processes, spawning 25 threads for each child process.
# So, a pool of 50 threads is left up and sleeping, ready to serve incoming requests.
# If more requests will come in, apache will spawn new child processes, each one spawning 25 threads,
# enlarging the thread pool until the total number of threads become 50. In that case, apache begin
# to cleanly drop processes, trying to reach 25 threads.
# New processes and its threads are spawned in case of a large spike of requests, until 200 parallel
# client requests are reached, then apache will no longer accept new incoming connections.
# When the load calm down, and requests come back under 200 parallel connections, apache will continue
# to accept connections. After 25, 000 requests served by a child, q. 1000 per thread, the process
# get closed by the father to ensure no memory leak is fired.
ServerLimit 16
StartServers 2
MaxClients 400
MinSpareThreads 25
MaxSpareThreads 50
ThreadsPerChild 25
MaxRequestsPerChild 1000
ThreadLimit 64
ThreadStackSize 1048576
And then some settings in fcgid.conf
FcgidMinProcessesPerClass 0
FcgidMaxProcessesPerClass 8
FcgidMaxProcesses 25
FcgidIdleTimeout 60
FcgidProcessLifeTime 120
FcgidIdleScanInterval 30
