I installed yum-priority and then installed VM pro; seems I should have set the priority to 1; thought I did; but maybe it got overwritten; anyway; now I have httpd-2.2.3-22.el5.centos.2 installed and I get this error Checking Configuration: The Suexec command on your system is configured to only run scripts under /var/www, but the Virtualmin base directory is /home. CGI and PHP scripts run as domain owners will not be executed.
I’m running CentOS 5.3 x64 with VM Pro script.
Is there a way to run a script to fix this problem?
