Hi Guys,
I have installed virtual min, on a system that initially had yum-plugin-priorities installed.
and have 2 questions after presenting all the information:)
EPEL repo activated
All the standard packages where installed also before installing virtualmin.
eg
dovecot
dovecot-mysql
postfix
postgrey
httpd
php
spamassassin
wget
htop
mariadb
mysql-server
phpmyadmin
So I used installed with the install.sh, and most things went fine, except I noticed httpd was coming from another REPO causing the SUEXEC wrong home dir error.
At installation, VirtualMin had no prioritie so would have defaulted to 99
can I use priorities and what should they be?
Now I am using
priority = 10 [virtualmin]
priority = 10 [virtualmin-universal]
priority = 15 [base]
priority = 15 [updates]
priority = 15 [extras]
priority = 20 [epel]
Also should I re-install from fresh?
Id prefer not as it seems just to be a package problem
My current issue is;
Resolving Dependencies
–> Running transaction check
—> Package mod_fcgid.x86_64 0:2.3.7-1.el6 will be installed
–> Processing Dependency: httpd-mmn = 20051115 for package: mod_fcgid-2.3.7-1.el6.x86_64
–> Finished Dependency Resolution
Error: Package: mod_fcgid-2.3.7-1.el6.x86_64 (virtualmin)
Requires: httpd-mmn = 20051115
Installed: 1:httpd-2.4.6-67.el7.centos.2.vm.x86_64 (@virtualmin)
httpd-mmn = 20120211
httpd-mmn = 20120211x8664
httpd-mmn = 20120211-x86-64
Available: 1:httpd-2.4.6-45.el7.centos.4vm.x86_64 (virtualmin)
Thanks for your time,
