I have a VPS with CentOS 64-bit and had virtualmin installed today.
I have 2GB RAM
I am use to cPanel and trying to learn as I go along.
I have ran the “Checking Configuration” and as it goes through it stops. I have disabled and prevented start on boot for mailman, spamassassin and clamav.
Your system has 1.83 GB of memory, which is at or above the Virtualmin recommended minimum of 256 MB.
Your Postfix version does not support per-domain outgoing IP addresses.
Apache is installed.
The following PHP versions are available : 5.4.24 (/usr/bin/php-cgi)
Webalizer is installed.
Apache is configured to host SSL websites.
MySQL is installed and running.
ProFTPd is installed.
Logrotate is installed.
SpamAssassin and Procmail are installed and configured for use.
The ClamAV program clamscan does not appear to be working properly :
ERROR: Can’t write to temporary directory
----------- SCAN SUMMARY -----------
Known viruses: 3090215
Engine version: 0.98.1
Scanned directories: 0
Scanned files: 0
Infected files: 0
Data scanned: 0.00 MB
Data read: 0.00 MB (ratio 0.00:1)
Time: 6.946 sec (0 m 6 s)
. Either change the program on the spam and virus scanners page, or disable this feature.
The thing is, I already have them disabled and they show they are disabled on boot.
I did the following just to be sure:
Stop webmin with: /etc/init.d/webmin stop
Look for a running Webmin process: ps auxw | grep miniserv | grep webmin
Use the "kill" command to kill any processes you find
Start up Webmin with: /etc/init.d/webmin start
What is wrong with the setup?
I have disabled all that is giving an error.
