I just install the virtualmin plugin on my webmin, as per instructed at http://www.webmin.com/vdownload.html
Installation looks okay, but the only thing is I kept receiving this message to re-check the configuration. The message is:
Sendmail is only accepting SMTP connections on the following ports : 127.0.0.1 port smtp. Email from other systems on the Internet will not be accepted. This can be changed in the Sendmail Mail Server module.
Please advise, thank you.
