Hi
I am sure that some of you are tired from (I assume) hearing about the same stuff going wrong…
Anyway… I have installed webmin and virtualmin. I needed an FTP access to my web content on the servers so I have installed the ProFTPd server module. In wiki I have read that normal UNIX users that were already created should be able to log in using FTP. It kinda worked… It logs in, then fails on MSLD and doesnt display any files. Now there is a plethora of information I can provide if you only let me know what you need to help me with this.
I am newbie to Linux and web-servers (on linux - I have made a switch from Windows).
Server stands behind a router and has all the necessary ports forwarded to it.
I have tried numerous configurations, new users, different permissions and I absolutely cant find anything wrong. I have spent 4 hours on this so far and went through numerous forums looking for an answer.
If there is anybody kind enough to help me I will appreciate it a lot.
Oh, I have tried anonymous and that didn’t work either (unless I have set it up wrong…)
This is what total Commander FTP client logs:
Connect to: (18/08/2012 23:55:46)
hostname=92.239.63.184:7575
username=pawel
startdir=
220 ProFTPD 1.3.4a Server (Debian) [::ffff:192.168.0.4]
USER pawel
331 Password required for pawel
PASS ***********
230 User pawel logged in
SYST
215 UNIX Type: L8
FEAT
211-Features:
LANG en-US.UTF-8;en-US*
MDTM
MFMT
TVFS
UTF8
MFF modify;UNIX.group;UNIX.mode;
MLST modify*;perm*;size*;type*;unique*;UNIX.group*;UNIX.mode*;UNIX.owner*;
SITE MKDIR
SITE RMDIR
SITE UTIME
SITE SYMLINK
REST STREAM
SITE COPY
SIZE
211 End
OPTS UTF8 ON
200 UTF8 set to on
Connect ok!
PWD
257 “/home/pawel” is the current directory
Get directory
TYPE A
200 Type set to A
PORT 192,168,1,73,219,182
200 PORT command successful
MLSD
PORT failed, try PASV mode!
PASV
HUGE Thank You in advance to anyone who will try to help me!!!
Kindest regards!
