In your pockettech.se.conf file, there should be a “VirtualHost” tag at the very top that looks something like this:
VirtualHost 1.2.3.4:80
Do you see something like that in there? It should be the first line of that file.
Whatever IP address is listed there, there should be a corresponding “NameVirtualHost 1.2.3.4:80” line in /etc/apache2/apache2.conf.
So, first off, you’d want to make sure that IP address matches the IP address on your server. And then second, you’d want to make sure that line exists in both .conf files.
<VirtualHost *:80>
SuexecUserGroup "#1002" "#1002"
ServerName pockettech.se
ServerAlias www.pockettech.se
ServerAlias webmail.pockettech.se
ServerAlias admin.pockettech.se
DocumentRoot /home/pockettech/public_html
ErrorLog /var/log/virtualmin/pockettech.se_error_log
CustomLog /var/log/virtualmin/pockettech.se_access_log combined
ScriptAlias /cgi-bin/ /home/pockettech/cgi-bin/
ScriptAlias /awstats /home/pockettech/cgi-bin
<Directory /home/pockettech/public_html>
Options -Indexes +IncludesNOEXEC +FollowSymLinks +ExecCGI
allow from all
AllowOverride All
AddHandler fcgid-script .php
AddHandler fcgid-script .php5
FCGIWrapper /home/pockettech/fcgi-bin/php5.fcgi .php
FCGIWrapper /home/pockettech/fcgi-bin/php5.fcgi .php5
</Directory>
<Directory /home/pockettech/cgi-bin>
allow from all
</Directory>
RewriteEngine on
RewriteCond %{HTTP_HOST} =webmail.pockettech.se
RewriteRule ^(.*) https://pockettech.se:20000/ [R]
RewriteCond %{HTTP_HOST} =admin.pockettech.se
RewriteRule ^(.*) https://pockettech.se:9999/ [R]
RemoveHandler .php
RemoveHandler .php5
IPCCommTimeout 31
<Files awstats.pl>
AuthName "pockettech.se statistics"
AuthType Basic
AuthUserFile /home/pockettech/.awstats-htpasswd
require valid-user
</Files>
Alias /dav /home/pockettech/public_html
Alias /pipermail /var/lib/mailman/archives/public
[[ conf partly removed from post to save space. ]]
</VirtualHost>
so it’s present as a wild card.
and in apache2.conf:
# Include the virtual host configurations:
Include /etc/apache2/sites-enabled/
NameVirtualHost 148.160.191.12:80
NameVirtualHost 148.160.191.12:443
The server is conf just as the virtualmin install.sh script left it. but i tried to change the wild card to the server IP … but it didn’t change anything.
