I got 4GB vps… but virtualmin shows 1GB…
before this, on other vps, I have 400GB diskspace, but it shows only 200GB…
anyone know how to solve this?
Are you using an OpenVZ-based VPS? Virtualmin may be showing you the amount of guaranteed memory that you have.
Regarding your disk space – what output does this command produce:
df -h
yup… OPENVZ…
on solusvm, shows 4GB RAM, 50GB space,
here the result:
Filesystem Size Used Avail Use% Mounted on
/dev/simfs 50G 2.6G 48G 6% /
none 2.0G 4.0K 2.0G 1% /dev
none 2.0G 0 2.0G 0% /dev/shm
# cat /proc/meminfo
MemTotal: 4194304 kB
MemFree: 1201324 kB
Cached: 425100 kB
Active: 657428 kB
Inactive: 324376 kB
Active(anon): 303500 kB
Inactive(anon): 253204 kB
Active(file): 353928 kB
Inactive(file): 71172 kB
Unevictable: 0 kB
Mlocked: 0 kB
SwapTotal: 0 kB
SwapFree: 0 kB
Dirty: 36 kB
Writeback: 0 kB
AnonPages: 556704 kB
Shmem: 4756 kB
Slab: 2011128 kB
SReclaimable: 1957048 kB
SUnreclaim: 54080 kB
Which Webmin version are you using?
There’s a bug report here where Jamie was trying to sort out some memory display issues:
https://www.virtualmin.com/node/27340
He pushed out a fix in Webmin 1.630 that should help with that.
As far as the disk space goes – what is it that Virtualmin is showing?
You had mentioned that you had 400GB of space, though the “df -h” is showing 50GB.
Im using latest version
I was with the same problem. Solved memory info with update “Fixes total and free memory display on OpenVZ systems”.
http://www.webmin.com/updates.html
-Carlos.
