Wp workbench not there
OS type and version Ubuntu 20.04.6 LTS
Webmin version 2.111
Virtualmin version 7.10 pro
Webserver version apache2?
apt install webmin-virtualmin-wp-workbench
This spins and runs for a while, throws no errors, but there is no ‘wp workbench’ in my navigation bar. No idea how to debug this.
Is the package actually installed? (dpkg -l webmin-virtualmin-wp-workbench)
# dpkg -l webmin-virtualmin-wp-workbench
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name                           Version      Architecture Description
ii  webmin-virtualmin-wp-workbench 2.1.2        all          Webmin module WP Workbench
looks to me to be installed
Are you logged in as a root user?
And, does the user-level WP Workbench appear under the Manage Web Apps for domains where you have WordPress sites?
Hello… Apologies for delay.
Yes, I’m logged in as root. When I switch to another user that has a domain with a virtualmin-installed WP, that user doesn’t see the nav link to wp workbench. I don’t see a ‘Manage Web Apps’ link at all?
Wait, are you really on Virtualmin version 7.10? That’s very old.
