So i have hit a new issue, i deleted all my virtual servers ( on purpose) in order to start fresh. I have never had issues before installing wordpress from the script but here is my problem:
The script runs fine and i get a url to complete the WP install, but when i click the url to do the usual, i am receiving
I am receiving error 404 not found.
The requested URL was not found on this server.
Apache/2.4.25 (Debian) Server at xyzxyz.net Port 80
scanned around on google changed the apache2 file as most things seem to suggest, but still nothing?? Any help thank you in advance!
i shall give it a whirl, but hopefully someone at virtualmin can maybe see if it is a bug as ive done a few websites this way before and never had any issues, but thanks for your reply Dibs
Good day so i tried it that way as per instructions and now when i navigate i get the apache default page ?? very strange goings on i might say.
Futher more i just tried to add phpmyadmin and i cant access that page correctly either getting the initial error - i have read lots and maybe its a user issue i do not allow root user logins - i set up the server with user with correct sudo creds, this problem has only arisen now though the set up was fine before i deleted the virtual servers.
What happens when you have an “empty” Virtual Server - i.e. no content in the public_html folder and just place a “hello world” type simple index.html file in there?
I’ve just run it on my server and I get one block of text per port 80 per Virtual Server and one block per port 433 (where enabled) per Virtual Server.
When I run that command, the top portion of the results is like the following:
$ sudo apachectl -S
VirtualHost configuration:
my.external.ip.address:80 is a NameVirtualHost
default server hostingDomain.com (/etc/apache2/sites-enabled/0-hostingDomain.com.conf:1)
port 80 namevhost hostingDomain.com (/etc/apache2/sites-enabled/0-hostingDomain.com.conf:1)
alias www.hostingDomain.com
alias mail.hostingDomain.com
alias webmail.hostingDomain.com
alias admin.hostingDomain.com
port 80 namevhost Domain1.com (/etc/apache2/sites-enabled/Domain1.com.conf:1)
alias www.Domain1.com
alias mail.Domain1.com
alias webmail.Domain1.com
alias admin.Domain1.com
and repeats with similar blocks for the other Virtual Servers.
i get nothing at all like that at all running that command. So im thinking of totally deleting this virtual server and starting again. i take it you use the virtualmin>create new virtual server setup ? All i am then doing is following the usual videos as i watched ages ago on the Vrtualmin youtube channel same with the wordpress install all though i dont seem to be doing anything at all different.
so what i did was install my main domain as it was before ALL-PC i can get to the WP install page as i want, yet the 2nd domain/virtual server i can not.
OUTPUT:
185.121.25.12:443 all-pc.net (/etc/apache2/sites-enabled/all-pc.net.conf:61)
185.121.25.12:80 is a NameVirtualHost
default server all-pc.net (/etc/apache2/sites-enabled/all-pc.net.conf:1)
port 80 namevhost all-pc.net (/etc/apache2/sites-enabled/all-pc.net.conf:1)
alias www.all-pc.net
alias mail.all-pc.net
alias webmail.all-pc.net
alias admin.all-pc.net
port 80 namevhost platoonarena.net (/etc/apache2/sites-enabled/platoonarena.net.conf:1)
alias www.platoonarena.net
alias mail.platoonarena.net
alias webmail.platoonarena.net
alias admin.platoonarena.net
ServerRoot: “/etc/apache2”
Main DocumentRoot: “/var/www/html”
Main ErrorLog: “/var/log/apache2/error.log”
Mutex fcgid-proctbl: using_defaults
Mutex ssl-stapling: using_defaults
Mutex proxy: using_defaults
Mutex ssl-cache: using_defaults
Mutex default: dir="/var/run/apache2/" mechanism=default
Mutex mpm-accept: using_defaults
Mutex fcgid-pipe: using_defaults
Mutex authdigest-opaque: using_defaults
Mutex watchdog-callback: using_defaults
Mutex proxy-balancer-shm: using_defaults
Mutex rewrite-map: using_defaults
Mutex ssl-stapling-refresh: using_defaults
Mutex authdigest-client: using_defaults
PidFile: “/var/run/apache2/apache2.pid”
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
Define: ENABLE_USR_LIB_CGI_BIN
User: name=“www-data” id=33
Group: name=“www-data” id=33
I’d suggest removing both Virtual Servers - create them again with only just HTTP enabled, place a “Hello World” test index.html file in the public_html folder of each (say “Hello World - Domain1” & “Hello World - Domain 2” files) and see if you can see them.
