I suspect what you’re seeing is the result of either the apache2-doc or httpd-manual package, depending on your distro.
If you have one of those installed, try removing them, and that should resolve that.
Alternatively, there’s a way to keep those packages installed, and remove the /manual alias… let us know what distro you’re using and we can offer some advice on that instead.
