WHMCS not creating accounts in virtualmin
I am trying to setup WHMCS with virtualim however I can`t seem to make whmcs create accounts on virtualmin.
I have configured everything correctly and whmcs seems to “see” virtualmin because it displays “server status” correctly.
The template name and plan name are exactly the same on both.
I have whmcs installed on the same server as virtualmin thus the same IP. Could this be the issue?
When I press create or suspend in whmcs I get this error: Error: “
Error - Document follows
” it appears exactly like this with the header tags.
It seems is was only a mater of “Tick to use SSL Mode for Connections” :slight_smile:
