WHMCS auto script didnt quite go to plan on a sub server
Hi guys,
gee i am going to burn this forum out with all my questions…
I setup a virtualmin Virtualserver then i setup a subserver as a subdomain of the parent…at least i think thats what i have done.
Virtual Server “mydomain.com.au”
sub server “whmcs.mydomain.com.au”
I ran the whmcs install script, however, it doesnt appear to have installed the database.
Below is the output (i have left out the downloading files part as that appeared all ok):
Configuring webserver PHP settings …
… done
Applying web server configuration …
… done
Now installing WHMCS version 7.1.1 …
Database setup did not succeed
More information on using this script can be found at http://www.whmcs.com/members/aff.php?aff=4115.
… installation was only partially complete.
Re-loading Webmin …
… done
… done
If this hasn’t been resolved (I see you said in another thread you have it installed, but maybe that didn’t happen via the Install Scripts installer), you can file a ticket, and Jamie will likely be able to help sort it out.
