I can’t see the version of virtualmin Use Ubuntu 20.04
I’m experiencing a white screen issue when accessing myip / 10000
I open the console and see these errors:
Failed to load resource: net :: ERR_CONNECTION_RESET manifest.json: 1 Failed to load resource: the server responded with a status of 403 (Access denied for 2xx.xxx.xxx.xxx) I use cloudflare to control my external dns. I have enabled ssl lets scripts.
You setup some of your hostnames in DNS to point to the Cloudflare proxy IPs, yes? OK, now setup a new name that is not pointing to Cloudflare proxies. Point it directly to your server IP.
Your server.domain AAAA record is still proxied, just saying.
Not sure if that makes any difference in the matter, whenever I use CF I tend not to proxy anything at all as it makes the whole setup a bit fragile.
Unfortunately my panel has not returned, is there another place that may have caused this?
Failed to load resource: net::ERR_CONNECTION_RESET
manifest.json:1 Failed to load resource: the server responded with a status of 403 (Access denied for 18x.xxx.x.xx)
Yes, it’s possible it’s firewall. I guess it’s even possible fail2ban has blocked your IP. But, I don’t think that’s the error you’d get. I think that looks like you’re still hitting a proxy.
Webmin also has an access log in /var/webmin/miniserv.log. If you’re hitting Webmin, you’ll see new entries appear. But, I’m almost 100% sure you’d get a different error if Webmin were refusing to talk to you for some reason (too many failed login attempts for instance, but I don’t think it ever blocks an IP, though fail2ban might…error would look different though).
