where to look for csf in webmin
I had virtual min
recently I installed csf also
any body how I can access csf from within my webmin?
This should do it if you have already installed CSF on your box:
  1. Go to Webmin > Webmin Configuration > Webmin Modules
  2. Select “From local file” > /etc/csf/csfwebmin.tgz > Install Module
Thanks I did it . Great but where is the seperate menue I can access it any time I want?
I’m not really sure what you mean.
If you’ve installed the Webmin CSF module - then you can manage your CSF firewall in your browser (via Webmin >> System >> ConfigServer Security & Firewall).
Other than that, the only option I know of is to use the command line.
Exactly Thanks a lot
