Quick question…
Dedicated server I am using has seperate mounts for /, /usr and /var.
They are rather small, but I can increase their size.
Where does the scheduled backup script store the gzipped file prior to transfer?
It’s failing right now due to an “out of space” error, so I assume it’s one of these mounts.
Thanks!
John P.
So, found that /tmp is hard coded in the backup scripts.
For the dedicated server I have, /tmp is mounted as a tmpfs drive. So, only 1 gig of room by default.
I can make it larger of course, but this would send much of the store to swap space.
mount -t tmpfs tmpfs /tmp -o size=10000M,mode=1777,remount
Could also unmount /tmp and make it a standard partition; albiet larger.
What would be good, would be to have a configuration setting that allows setting a specific “temp” location for backups.
John P.
Eric
3
Yeah, as you saw, it uses /tmp by default.
However, you can change that to use another path by going into Webmin -> Webmin -> Webmin -> Configuration -> Advanced Options.
From there, you can set the tmp directory to use a partition that has more space.
