when using wordpress script on virtualmin pro no admin user is created
Hi All,
When I use the virtualmin pro installer for wordpress i can do the steps for installation e.g. select admin name and password.
virtualmin installation is a fresh one on ubuntu Ubuntu Linux 14.04LTS
then when the setup wants to go to step 2 nothing happened a blank page is presented ( seems that the script is not completely executed)
when i take a look in the database, no admin user is created and the sit is unreachable.
the same happens when i take the standard installer from wordpress,
file and directory rights are exactly the same as the old one…
I got stuck on this.
Anyone?
When performing a Wordpress installation using the Install script, what output do you see in Virtualmin during the installation process?
And when attempting the Step 2 that you mentioned above, do you see any errors in the Apache logs for that domain, located in $HOME/logs/error_log?
howdy,
the following
[fcgid:warn] [pid 3177] [client xxx.xxx.xxx.xxx:58714] mod_fcgid: stderr: PHP Warning: require(/home/**/public_html/wordpress/wp-includes/functions.php): failed to open stream: Permission denied in /home//public_html/wordpress/wp-settings.php on line 72
[Wed Jul 30 14:37:53.200713 2014] [core:error] [pid 3177] [client xxx.xxx.xxx:61204] End of script output before headers: install.php, referer: http://********l/wp-admin/install.php?language=en_US
line 72 refers to:
functions.php
// Load early WordPress files.
require( ABSPATH . WPINC . ‘/compat.php’ );
require( ABSPATH . WPINC . ‘/functions.php’ );
require( ABSPATH . WPINC . ‘/class-wp.php’ );
require( ABSPATH . WPINC . ‘/class-wp-error.php’ );
require( ABSPATH . WPINC . ‘/plugin.php’ );
require( ABSPATH . WPINC . ‘/pomo/mo.php’ );
looks like an absolute path it cannot find …
but why is this happening?
So far, I haven’t been able to reproduce the issue you’re seeing.
What distro/version are you using? And are you using that distros default PHP version?
Is there anything in the public_html directory of that domain that might cause problems for sub-directories, such as a .htaccess file?
Also, does this problem only occur for this one domain? Or does it happen when installing WordPress into other domains on your server?
it’s all standard with only one domain so I cannot test it with anther domain,
I tried installing it in public_html and in a sub directory both gave the same result
public_html is completely emty exept for some other installed scripts which are working fine.
