What should write Postfix configuration ?
I recorded a new virtual server and now if I click on List Virtual Servers and then re-check and refresh configuration tells me
  A problem was found with your Postfix virtual maps : No map sources were found in the Postfix configuration
have exactly the same problem with new installation of Virtualmin Pro on Debian 4.0
Then there is a solution to solve the problem I am?
The new version of Webmin broke the automated installation. I believe it is fixed with the latest version I rolled out an hour or so ago, but I might be wrong (testing is still in progress). See this news post about it:
http://www.virtualmin.com/forums/news/installer-issues-due-to-new-webmin-versions.html
I said that does not find virtualmin-base
What OS/version are you on, zonekjdx?
linux ubuntu server 7.10
That’s not a supported OS by our installer. No way it can possibly work…as there is no repository for Ubuntu 7.10.
Then I can not use
I have the same problem on Debian 4.0 Etch after a fresh Installation:
How can I fix it?
For the moment they are not yet able to solve the problem even I
Hello. I just fixed this problem.
Go to Webmin > Servers > Postfix > MailAliases
Where it says at the top:
[color=#0000FF]"Alias databases used by the local delivery agent"[/color]
Check the right hand radio button and type:
[color=#008000]hash:/etc/aliases[/color]
In the box.
That should fix it at least for Debian 4.0
You’ll most likely need to add a couple of apache modules too, in:
Webmin > Servers > apacheWebserver > GlobalConfiguration > configureApacheModules.
I had to add actions and suexec
I think there was one more error too, but can’t remember what it was.
I hope that helps you ou a bit.
Go to:
Webmin > Servers > PostfixMailServer >MailAliases
and type the following into the "Alias databases used by the local delivery agent" field.
hash:/etc/aliases
Check the radio button and save.
That got my postfix working on Debian 4.0
I have done so but not yet :frowning:
I have the same problem, I tried the steps above, and everything looks correct. I have a fresh install of Debian 4.0 RC3.
The error I get is: "A problem was found with your Postfix virtual maps : No map sources were found in the Postfix configuration"
Any ideas?
Hey guys,
See this thread in the News forum about this issue:
It’s a known problem with a simple solution. :wink:
I use ubuntu 7.10 servers do so:
Dpkg-r virtualmin-base
… The package is not installed
Apt.get install virtualmin-base
impossible to find Virtualmin-base
I do not know what to say but I virtualmin screen webmin can choose either virtualmin that webmin
Dpkg -r virtualmin-base
Apt-get install virtualmin-base
I correct typo:)
I want to help solve and start working with my server because I just sit in a function and do not understand how to operate if this does not work well virtualmin
I tried this as well with no luck, I get the same error.
[code:1]virtualmin1:~# Dpkg -r virtualmin-base
-bash: Dpkg: command not found
server:~# dpkg -r virtualmin-base
(Reading database … 63420 files and directories currently installed.)
Removing virtualmin-base …
server:~# Apt-get install virtualmin-base
-bash: Apt-get: command not found
virtualmin1:~# apt-get install virtualmin-base
Reading package lists… Done
Building dependency tree… Done
The following NEW packages will be installed:
virtualmin-base
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0B/9990B of archives.
After unpacking 34.8kB of additional disk space will be used.
Selecting previously deselected package virtualmin-base.
(Reading database … 63419 files and directories currently installed.)
Unpacking virtualmin-base (from …/virtualmin-base_1.0-14_all.deb) …
Setting up virtualmin-base (1.0-14) …
server:~#
[/code:1]
Any ideas?
