The help is sort of confusing. It says it will also run a server owner, just like FCGid does.
So, is it merely running the PHP code and starting up PHP each time as opposed to a waiting mod_fcgid process? Is that the difference?
It would be the same security then, right?
Joe
2
Correct.
Yes.
Yes.
So, what’s confusing? How should we reword it to make it more obvious that your first guesses about what it means are exactly correct?
