Protected Web Directories
Digest encryption is enabled in the module configuration, but the htdigest command needed for it is not installed.
This is on Suse 10.0
I think there was a bug about this (maybe you filed it, even). SUSE calls it htdigest2 on Apache version 2…Anyway, I think this has been fixed in a recent version. If not, it’s definitely bug-tracker material.
Adam,
I fixed this with a simlink from htdigest2 to htdigest. Virtualmin was calling htdigest SuSE renamed this to htdigest2. With the symlink in place all is well.
Adam,
See closed bug #216 for more info.
