Hi all
What base environment should I choose when installing CentOS 7 to be used with Virtualmin?
Thanks in advance.
- Tim
Hi all
Thanks in advance.
It doesn’t really matter too much, I’d just recommend choosing one that isn’t a desktop-based install.
So long as you’re using a server install, it should work well.
I usually use minimal, though when doing that you may sometimes need to manually install perl and wget.
Hi Eric
Perfect, just what I needed
