hello, i have installed Webmin/Virtualmin on a couple of VPSs running on ubuntu 20.04. But every time I create a virtual server in the process it says Webmin failed to start and currently not running. Some about 4 to 5 days ago I never faced this issue until yesterday. why is Webmin failing to start and not running?
However, when I run a command from the terminal it would start running but again it would stop, and need to go to the terminal again to start it. How can I fix this? kindly help
@Ilia Thanks a lot I ran that command on the same system where I was having the Webmin issue before and now the problem is solved. Much appreciated and noted about the fix coming up in the subsequent updates
