webpage is not available after reboot at fresh Virtualmin installation
I just successfully installed and configured Virtualmin on Linode Ubuntu 12.04 LTS. The webpage asked me to reboot. Unfortunately, after I reboot, my https://ipaddress:10000/ shows “webpage is not available”.
I first tried:
/etc/init.d/webmin start
update-rc.d webmin defaults
I got the following message:
update-rc.d: warning: webmin start runlevel arguments (2 3 4 5) do not match LSB Default-Start values (2 3 5)
System start/stop links for /etc/init.d/webmin already exist.
I then tried:
cd /etc/init.d
rm …/rc?.d/???webmin
Adding system startup for /etc/init.d/webmin …
/etc/rc0.d/K20webmin -> …/init.d/webmin
/etc/rc1.d/K20webmin -> …/init.d/webmin
/etc/rc6.d/K20webmin -> …/init.d/webmin
/etc/rc2.d/S20webmin -> …/init.d/webmin
/etc/rc3.d/S20webmin -> …/init.d/webmin
/etc/rc4.d/S20webmin -> …/init.d/webmin
/etc/rc5.d/S20webmin -> …/init.d/webmin
I am totally newbie, please help! Thanks, Amy.
Well, let’s start here – when you started the Webmin process from the command line, did it work properly at that point?
root@alex:~# /etc/init.d/webmin start
root@alex:~#
I modified the “Default-Start from 2 3 5 to 2 3 4 5” in /etc/init.d/webmin file, as attached. Now, I got the following message:
root@alex:~# sudo update-rc.d webmin defaults
root@alex:~#
I added the following line to iptables and restarted webmin, problem fixed.
-A INPUT -p tcp -m tcp --dport 10000 -j ACCEPT
http://www.webmin.com/firewall.html
