Webmin won't start Apache
I have been following this walkthrough on setting up a Linux server. http://www.howtoforge.com/lamp_installation_ubuntu6.06 and everything was going good until I had to change my listening port from 80 to 8080.
Well, after I turned off Apache2, I could not get it back on.
When I try to load apache, I get the following error.
Failed to start apache:
*Starting apache 2.0 web server…
Syntax error on line 392 of /etc/apache2/apache2.conf:
Port was replaced with Listen in Apache 2.0
…fail!
Anyways, If you take a look at the walkthrough, that is EXACTLY what I have done so far. Nothing extra or more.
If anyone could help me that would be awesome.
P.S. I have also tried returning the port settings to 80 but I still have the same error.
In httpd.conf, on the line where you put 8080 (and then back to 80), change the word "Port" to "Listen".
