Hey Support,
Do you ever think that you might create a “Webmin Wiki” or a “Virtualmin Wiki” ???
(I’ve noticed a few more “SOLVED” entries in the forums recently, but sometimes it can be exhausting to read thru an entire forum post trying to sort out the answer)
Keep up the good work, great products!!
EDIT: Nevermind, I found the “search” under the SUPPORT link… which is probably what you would suggest I do.
