Webmin web interface is not available
I installed hundreds of times Virtualmin/Webmin on Linux machines. This is a fresh install Debian 7.8/Virtualmin.
  1. I login into Webmin account then I visit some sections. Over a while I get page not found for a section then the whole webmin content is not found.
  2. I refresh the window, I can start again visiting sections, but over a while without activity visiting a section I get page not found.
  3. I restarted webmin service. Same behavior. I restarted the whole server, same behavior.
Service webmin is running. I really don’t understand what is going on. You can see in attachment the page I get in Chrome.
Hmm, that’s pretty unusual! What theme is it that you’re using there? Are you by chance using a non-default theme of some sort?
This is Debian 7.8 + Virtualmin install from scratch. Nothing more. All out of the boxes without any modification. As I said I installed hundreds of time this combination without any issues. The theme is the default one.
I will do again a test using different browsers and checking if webmin service is running. I will watch repositories too. Then I will install all from scratch the whole stuff. It is a basic installation Debian then Virtualmin (install.sh).
I’m unfortunately not quite sure what might cause that, I haven’t heard of issues like that occurring on a default installation of Virtualmin.
Another thing you could try checking is to look at the Webmin error logs in /var/webmin/miniserv.error to see if anything in there is helpful.
Hello Eric,
I re-installed everything from scratch, a minimal installation. Debian 7.8 + Virtualmin. As repositories I have Debian originals for security and software, and what Virtualmin adds at installation.
  1. Chrome has a problem for sure. I opened Firefox and Chrome together. Firefox did not get any 404 error even after 30 minutes of visiting links, Chrome after 2 - 3 minutes has errors, in both sections (menu and window content). Without refreshing the browser you cannot continue using Webmin, but is again for 2 - 3 minutes. My OS is Windows 7 Ultimate x64 updated, same for Chrome latest version. I will check Chrome in Ubuntu to see what is happening. I will come back with insides when I finish this.
  2. I attached for you miniserv.error. There are a lot of errors in /usr/share/webmin/virtual-server-theme/newleft.cgi. Please note this is the original theme. I installed Debian then Virtualmin, no changes anywhere. Take a look over the errors maybe there are issues related to Virtualmin that should be corrected to make Chrome works again.
Thank you.
Sorry, this forum is not allow adding attachments, even it is a zip file 1.04Kb in size:
miniserv.error
[01/Apr/2015:12:07:46 +0300] miniserv.pl started
[01/Apr/2015:12:07:46 +0300] Using MD5 module Digest::MD5
[01/Apr/2015:12:07:46 +0300] PAM authentication enabled
[01/Apr/2015:12:09:03 +0300] Reloading configuration
[01/Apr/2015:12:09:05 +0300] Reloading configuration
[01/Apr/2015:12:09:06 +0300] Reloading configuration
[01/Apr/2015:12:09:07 +0300] Reloading configuration
[01/Apr/2015:12:09:11 +0300] Reloading configuration
restarting miniserv
[01/Apr/2015:12:09:12 +0300] Restarting
[01/Apr/2015:12:09:15 +0300] miniserv.pl started
[01/Apr/2015:12:09:15 +0300] Using MD5 module Digest::MD5
[01/Apr/2015:12:09:15 +0300] PAM authentication enabled
Failed to initialize SSL connection
[01/Apr/2015:12:10:30 +0300] [192.168.159.1] Document follows : This web server is running in SSL mode. Try the URL https://192.168.159.139:10000/ instead.
[01/Apr/2015:12:10:32 +0300] [192.168.159.1] Document follows : This web server is running in SSL mode. Try the URL https://192.168.159.139:10000/ instead.
Use of uninitialized value in pattern match (m//) at /usr/share/webmin/virtual-server-theme/newleft.cgi line 40.
Use of uninitialized value in numeric eq (==) at /usr/share/webmin/virtual-server-theme/newleft.cgi line 51.
Use of uninitialized value $gaccess{“webminsearch”} in string ne at /usr/share/webmin/virtual-server-theme/newleft.cgi line 151.
Use of uninitialized value in string eq at /usr/share/webmin/virtual-server-theme/newleft.cgi line 173.
Use of uninitialized value in string eq at /usr/share/webmin/virtual-server-theme/newright.cgi line 30.
[01/Apr/2015:12:12:59 +0300] Reloading configuration
Use of uninitialized value within %gconfig in numeric eq (==) at /usr/share/webmin/virtual-server-theme/newleft.cgi line 91.
The error you’re seeing there is a warning that’s been showing up in recent Virtualmin versions… that shouldn’t be the cause of any problems though. That warning is occurring in my Virtualmin version as well.
And unfortunately, I don’t seem to be able to reproduce that issue :slight_smile:
We also haven’t heard any other reports of other users seeing an issue accessing Virtualmin in Chrome for Windows.
Do you happen to have a different PC that you could use to try accessing Virtualmin with?
I’m wondering if it’s an issue with that particular system, or perhaps some kind of issue with the server.
I posted this as an issue related to Webmin.
I will check Google Chrome on Windows 7 Ultimate and 8.1 installed in VM’s from scratch. Keep you updated.
This is a Chrome problem. In Windows 7 x64 Ultimate after a while pages are not found. You have to reload the page, but after a short time it crashes again.
I did a manually remove for Chrome, I installed again, same issue. I thought it was related only to VM’s. I accessed products servers, same behavior.
It is not a Webmin problem because other browsers like Firefox or Internet Explorer are working as expected.
UPDATE: I disabled the antivirus (AVG 2014) and things seem to be back to normal. It is very strange because both programs were just automatically updated. There were no changes in software in this machine because I am using VM’s to do the dirty stuff.
If the problem continues I will go back to Windows Defender. To those who are using this combination AVG + Chrome in Windows, please pay attention to this issue. I hope to find a solution with AVG staff. Something change in this program over updates.
