I’m running Virtualmin(GPL) and Webmin 1.35 on FreeBSD 6.0 with Apache22 and am baffled by an issue I cannot resolve. When I select the Webmin Apache server module, the virtual servers I’ve defined (using Virtualmin) are not displayed even though I’ve specified the path for the virtual hosts as /usr/etc/local/apache22/extra/httpd-vhosts.conf. I’ve confirmed Virtualmin does correctly append the new virtual host to this file, but it appears Webmin is not parsing it to determine virtual host definitions.
Additionally, I’ve added the subversion plugin, and when I add a new host through Virtualmin an error stating the no virtual host is defined is thrown when Virtualmin attempts to enable subversion.
I dunno. Sounds like maybe a bug, but it could also be a problem with the configuration (but the fact that Virtualmin actually appends to the file hints otherwise). I’ll ask Jamie to have a look at this thread.
That was it - when I used an absolute path rather than the relative path, Webmin did display the virtual servers correctly under the apache server module. (BTW, Apache did parse the relative path correctly after adding vhosts using Virtualmin.)
That would explain it - when Webmin see a relative path, it assumes that it is relative to the Apache root directory, which is set on the Module Config page of the Apache module. In your case, it probably wasn’t set correctly, since you appear to have a custom compiled version of Apache installed…
