Nothing comes up for Webmin>System>Bootup and Shutdown. The server has been restarted a couple times, but the problem persists… but it used to work fine.
Where should I look to get a clue into what is going on?
Thanks!
Webmin version 1.600
Virtualmin version 3.94.gpl GPL
Our whole infrastructure is built on CentOS, both 5.9 and 6.3 currently. We’ve never seen this issue, so it seems odd others are. Was there anything done to your system recently, that may have caused the problem? In order to correct an issue, it needs to be reproduceable, and/or error logs need to indicate what the issue is, otherwise it’s like a needle in a haystack if it happens to some, but not every instance.
I suggest, if anyone is facing this issue currently, they add their comments to the “Issue” that “LonDoh” opened at:
nothing notable had/has been changed on the system
In fact when i first posted it was a (almost) new install (…I dont often use that screen but its often handy when setting up)
as I said I upgraded to latest dev version at that time, still on 1.614, same error
by ‘nothing weird in logs’ I meant these logs:
miniserv.error
miniserv.log
webmin.log
syslog
and webmin.debug - I turned on wm debugging then, and tried again now, but nothing obvious shows when accessing errant screen or otherwise.
issue appears with ff or opera
There are no console errors in browser
The fact it isnt happening in your case doesnt mean it isnt happening in mine/others.
If I dev team want specific info or access I’m happy to oblige - just need to ask.
But letting weeks go by without a response doesnt help it get pinpointed/fixed/me turned back to a happybunny
I see, well we use only stable version here so I can’t really comment on what may or may not be working in a “dev” version, hence because they there is a potential for bugs within these releases.
Just so you know though, Webmin 1.615 has been released today.
I see
whilst I am grateful for your input, I’m not exactly sure you do see
as I said before:
I just upgraded wm to latest devel version 1.614
So that was during setup and to see if it fixed the issue - which it didnt
I’m also not at all minded to go and throw another beta at a (now) live box, unless I’m sure there are definitely no probs and definitely some benefit.
no doubt there’s a changelog somewhere.
But it’s no big deal, it’d just be nice if it worked thats all.
