Webmin processes won't start
I’ve had Virtualmin running for a while but, for apparently no reason Virtualmin crashed and will now not restart.
I’ve tried killing all processes and restarting it but it just doesn’t seem to start. Rebooting doesn’t help either
I’m not sure what else to try and where to even start looking to find the problem…
I figured out the problem. I had redirected the home folder to a new drive a day or two back and mustn’t have been in Webmin since, just on the sites (which all worked fine)
I had the following in /etc/fstab/
UUID=xxxxx /home ext4 defaults 0 2
whereas when I replicated the settings flags from the main partition and rebooted it all worked fine. For reference below is what I changed it to…
UUID=xxxxx /home ext4 grpquota,discard,usrquota,rw 0 2
Cheers
Daniel
I’m glad you got that figured out – thanks for letting us know how you fixed it!
