On the left hand side, there is a selection in the menu title “Webmin Modules” in Virtualmin. I was hoping that it would show all enabled webmin modules for the user, but alas it does not.
Is there a screen to set which modules show up there? I’d like to turn off the webmin tab, so that all modules show in in Virtualmin.
I believe that menu is meant as a convenience function, offering some Webmin modules that are considered to be popular, or perhaps useful to Virtual Server owners.
I’m not aware of a way to add or remove them from that list, nor aware of a way to remove the Webmin tab.
If those are features you’d like, you may want to submit a feature request using the Support link above.
