I disregarded the first time this happened, but this is the 2nd time this happens and I decided to report it. Webmin uses up all the available RAM, seemingly out of nowhere. The last time anyone logged or made changes to webmin was days ago. Below is the output of “ps -e -orss=,args= | sort -b -k1,1n | tail -n 20” at the time free RAM goes below 600mb (on a 16gb system that usually runs at 40% of RAM capacity)
The first time it happened was on august 10th, and I usually run pretty tight updates, so on that date I was most likely running the most current version available.
This time I am running:
CentOS 6.4 (2.6.32.60-40.art.x86_64)
ASL 3.2.14-31.el6.art
Webmin 1.6.5
Virtualmin 4.02.gpl
Apache 2.2.15
PHP 5.3.3 (mod_fcgid/2.3.7)
Look at the last line:
11660 /usr/bin/perl /usr/libexec/webmin/miniserv.pl /etc/webmin/miniserv.conf
16332 /usr/bin/newrelic-daemon -A -s -l /var/log/newrelic/newrelic-daemon.log
16760 /usr/bin/php-cgi
22556 /usr/bin/perl /usr/libexec/webmin/status/monitor.pl
45788 /usr/bin/php-cgi
70944 /var/asl/usr/sbin/tortixd
71360 /usr/bin/php-cgi
71436 /usr/bin/php-cgi
73748 /var/asl/usr/sbin/tortixd
76824 /usr/bin/php-cgi
78668 /usr/sbin/httpd
84604 /usr/sbin/httpd
84636 /usr/sbin/httpd
85208 /usr/sbin/httpd
85476 /usr/sbin/httpd
85652 /usr/sbin/httpd
90844 /usr/sbin/httpd
245472 clamd
587480 /usr/libexec/mysqld --basedir=/usr --datadir=/var/lib/mysql --user=mysql --log-error=/var/log/mysqld.log --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/lib/mysql/mysql.sock
11789388 /usr/libexec/webmin/shell/index.cgi
7380 /usr/sbin/named -u named
8828 /usr/bin/perl -w /usr/bin/psmon --daemon --cron
9360 /var/ossec/bin/ossec-analysisd
9536 /var/ossec/bin/ossec-dbd
16756 /usr/bin/php-cgi
17908 /usr/bin/newrelic-daemon -A -s -l /var/log/newrelic/newrelic-daemon.log
22860 /usr/bin/perl /usr/libexec/webmin/status/monitor.pl
66144 /usr/bin/php-cgi
70356 /var/asl/usr/sbin/tortixd
73328 /var/asl/usr/sbin/tortixd
78648 /usr/sbin/httpd
84456 /usr/sbin/httpd
84484 /usr/sbin/httpd
84488 /usr/sbin/httpd
84512 /usr/sbin/httpd
84588 /usr/sbin/httpd
91184 /usr/sbin/httpd
256496 clamd
617892 /usr/libexec/mysqld --basedir=/usr --datadir=/var/lib/mysql --user=mysql --log-error=/var/log/mysqld.log --pid-file=/var/run/mysqld/mysqld.pid --socket=/var/lib/mysql/mysql.sock
11601980 /usr/libexec/webmin/shell/index.cgi
