Operating system: Debian
OS version: Stretch 9.13
I hope I am in the correct location to ask this question.
I am following a procedure and the next step is to install webmin
The processor albeit old is capable of running the above operating system and is armel (Buster will not run).
I need to know which version of webmin is the one to use on the armel architecture.
Does 1.970 cater for all architectures and also suitable for the above OS?
Should I be here https://www.webmin.com/deb.html ?
Thanks in advance
What is “armel”?
Nevemind, I see it’s a type of ARM CPU.
Webmin don’t care, it’s all Perl, but you can’t (easily) run Virtualmin on it.
