Since i have upgraded, Webmin to 1.870, I’m experiencing interface freeze either when I’m walking around in the interface, or also each time I’m trying to apply/save a new config in any Webmin/Virtualmin module.
When this happen the loading bar on the top is moving right to left forever(at least for the max 10mins I have waited), and the CPU is doing regular pic at 100%
The left and right panel are still usable but I can’t switch to any other place, the only option I have is to log-out and then log back in again,the UI gets then become back useable for few minutes until it got stuck again…
Also as you’ll see in the screenshot below index_cpu.cgi is always using quite a lot of CPU from 15%-20% constantly.
Using Webmin Framed them I don’t experience this issue anymore…
Here some details about the server:
Operating system Debian Linux 9
Webmin version 1.870
Virtualmin version 6.01.gpl
Kernel and CPU Linux 4.9.0-4-amd64 on x86_64
Processor information Intel® Xeon® CPU E5-2620 v2 @ 2.10GHz, 2 cores
Real memory 366.52 MB used, 5.83 GB total
What i called the framed theme, is the old standard them, you can switch to this old theme by clicking on the gear , at the bottom left of the main page, then go to change tab and choose the Gray framed theme.
You’ll be probably be a bit surprised by the change, but mostly you have everything you need, until the fix is pushed to the stable authentic theme release.
Other option as stated below is to use the Authentic Dev release, but you have to expect other bugs potential.
