For the first time I am also experiencing high CPU loads every time collectinfo.pl
runs on my server (a VPS).
This has started happening only recently, like maybe since the last Webmin upgrade? Now every time this status collecting script runs, my server loads spike and slows everything else running on this server.
I also only recently noticed that webalizer
was also running every time collectinfo.pl
ran. top
reports that webalizer
was running at 99% CPU for as long as it was alive, which in my opinion, is probably the real culprit for the extreme server loads. Naturally, I quickly disabled webalizer reporting for each virtual server (I only have 2 on this server) but the webalizer
script keeps running every 5 minutes with collectinfo.pl
Then I disabled it via
System Settings > Virtualmin Configuration > Advanced options
and setting ‘Setup Webalizer Cron job for each virtual server?’ to no.
Even after that, webalizer
still keeps running every 5 minutes with 99% CPU (for approx. 27 secs. each time).
I suppose I could uninstall webalizer altogether - but before that I thought I’d post here to see if I missed something.
I just want to know how can I control that webalizer
does not run with the collectinfo.pl
script?
