I’m new user and i don’t have too much knowledge with web hosting. Last time I bought VPS with CentOS8 64 bit from contabo and installed Virtual min and copied my old website folder to new VPS no problem. After that last two day ago i bought same VPS but CentOS 8 Stream 64 bit and installed Virtual min. That time after copy website folder webpage don’t run and only show text with php something like that
<?php
* Front to the WordPress application. This file doesn't do anything, but loads
* wp-blog-header.php which does and tells WordPress to load the theme.
* @package WordPress
* Tells WordPress to load the WordPress theme and output it.
* @var bool
define( 'WP_USE_THEMES', true );
/** Loads the WordPress Environment and Template */
require __DIR__ . '/wp-blog-header.php';
I don't know how to do and how to fix. Anyone can help me?
Usually this happens when mod_php is installed (often people install all “php” packages thinking that’s a reasonable thing to do when adding another PHP version or whatever…the package named “php” is mod_php and should never be installed on a modern system).
The package includes a config file that overrides Virtualmin PHP configuration, so when you install it or upgrade it, it breaks PHP apps in Virtualmin. So, don’t install mod_php (the package named “php” in the case of the default PHP version, but it’ll probably be something like “php7.4-php” if you’ve installed some other PHP version(s)). There is never any reason to use mod_php for any deployment today, and it should not exist on your system.
And then one more thing i want to install 5 server with one domain name so what virtual min package i need to buy. And when i face error like that support chat can use or not. Normally i never change server setting only change website from wordpress login page. But One thing every month i change hosting plan depend usage and so every month i need to install new virtual min at VPS.
Hi Thank for reply me. This is my install procedure last time i installed 3 server is ok. The last server happen like that. Can you explain detail how to fix and where to fix. Because i don’t have too much knowledge and still learning googling and youtube learning. This is my install procedure. I bought VPS and enter ip address at putty and type username and password and then start this procedure. After that copy public_html folder under home directory.
Install Virtual Min
wget http:// software.virtualmin. com/gpl/scripts/install.sh
sudo /bin/sh install.sh
Wherever you got the suggestion to do this was wrong.
You should never install the php package. It contains mod_php and causes the problem you are having. You do not need mod_php and you should not install it, and since you have installed it, you should uninstall it. I do not know how to be more clear.
