My domain is: app.marketplaza.pe
I ran this command: I went to virtualmin chose server configuration then manage ssl certificate then generate certificate using let’s encrypt. I chose to apply certificate only to subdomain which has an A record pointing specifically only this subdomain to current webmin server.
It produced this output:
Requesting a certificate for app.marketplaza.pe from Let’s Encrypt …
… request failed : Web-based validation failed : Failed to request certificate :
File “/usr/libexec/webmin/webmin/acme_tiny.py”, line 198, in
main(sys.argv[1:])
File “/usr/libexec/webmin/webmin/acme_tiny.py”, line 194, in main
signed_crt = get_crt(args.account_key, args.csr, args.acme_dir, log=LOGGER, CA=args.ca, disable_check=args.disable_check, directory_url=args.directory_url, contact=args.contact)
File “/usr/libexec/webmin/webmin/acme_tiny.py”, line 149, in get_crt
raise ValueError(“Challenge did not pass for {0}: {1}”.format(domain, authorization))
ValueError: Challenge did not pass for app.marketplaza.pe: {u’status’: u’invalid’, u’challenges’: [{u’status’: u’invalid’, u’validationRecord’: [{u’url’: u’http://app.marketplaza.pe/.well-known/acme-challenge/XXTZO8eLKhoUK2YTTUr5vH3Ujk00Q0HqcYuIB3TkFFA’, u’hostname’: u’app.marketplaza.pe’, u’addressUsed’: u’165.227.54.45’, u’port’: u’80’, u’addressesResolved’: [u’165.227.54.45’]}], u’url’: u’https://acme-v02.api.letsencrypt.org/acme/chall-v3/6501963603/cSzYgw’, u’token’: u’XXTZO8eLKhoUK2YTTUr5vH3Ujk00Q0HqcYuIB3TkFFA’, u’error’: {u’status’: 403, u’type’: u’urn:ietf:params:acme:error:unauthorized’, u’detail’: u’Invalid response from http://app.marketplaza.pe/.well-known/acme-challenge/XXTZO8eLKhoUK2YTTUr5vH3Ujk00Q0HqcYuIB3TkFFA [165.227.54.45]: “\r\n\r\n\r\n \r\n <meta http-equiv=\“X-UA-Compatible\” content=\“IE=edge\”>\r\n <tit”’}, u’type’: u’http-01’}], u’identifier’: {u’type’: u’dns’, u’value’: u’app.marketplaza.pe’}, u’expires’: u’2020-08-20T04:32:58Z’}
, DNS-based validation failed : Only the offical Let’s Encrypt client supports DNS-based validation
My web server is (include version): Apache versión 2.4.6
The operating system my web server runs on is (include version): Cent OS 7
My hosting provider, if applicable, is:
I can login to a root shell on my machine (yes or no, or I don’t know):yes
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):
Webmin 1.954 with Virtualmin
The version of my client is (e.g. output of certbot --version
or certbot-auto --version
if you’re using Certbot):
