Warning! A problem was detected with your Virtualmin license
I suddenly getting this error on the GPL version. Has something changed with the licensing of the GPL version?
Update, I just noticed I’m using the pro version. Not sure how that happened as I’ve never installed the pro version. Would this happened during a update?
Ive found docs on going back the GPL version at
https://www.virtualmin.com/documentation/installation/uninstalling
Steve
Ok, pro is still there. Anyone else having the issue?
Steve
The same issue after recent update. 4 servers.
It looks Virtualmin experts killed GPL version.
Any comment?
Update your system. The “switched to Pro” bug was fixed days ago. It should fix itself if you update. If it doesn’t, do you not see version 6.10-2 of wbm-virtual-server in the repo?
If an update doesn’t fix it the manual solution is here:
on CentOS Linux 7.8.2003 a
yum clean all
yum update
solve it all !!! thanks @Joe for your work. :wink:
Thanks, virtualmin’s update kept failing but update of with yum fixed the issues.
Steve
