Ive just put in a new server and installed virtualmin… It all looks to be running ok at the start, but then i started having problems doing things that were easy on my last server.
Spam filtering/Virus filtering wasn’t working… i checked the logs and it was complaining about domain-lookup.pl and another file was missing… so I copied these files from my other server - all working no problem.
Awstats isnt allowing me to view the graphs unless im going through virtualmin. i get nasty errors:
Error: Not same number of records of BrowsersSearchIDOrder (118 entries) and BrowsersHashIDLib (117 entries without msie,netscape,firefox,svn) in Browsers database. May be you updated AWStats without updating browsers.pm file or you made changed into browsers.pm not correctly. Check your file /usr/share/awstats/lib/browsers.pm is up to date.
Setup (’/etc/awstats/awstats.www.domainname.conf’ file, web server or permissions) may be wrong.
Check config file, permissions and AWStats documentation (in ‘docs’ directory).
- Bandwidth monitoring doesnt appear to be working? i even tried to speed it up by running the cronjob for "bw.pl" no luck…
Any suggestions on what i could do? perhaps a re-install or something… its currently in a live production and i dont want any downtime.
Cheers in advance.
