That wasn’t enough for my setup using Virtualmin Pro that we just purchased.
Problem is that debian installs the .so libs into a sub-folder:
/usr/lib/php5/20060613+lfs
so I spent some hours trying to find why it didn’t load MySQL extension in php5 !
I added directive to /etc/php5/apache2/php.ini (using in apache 2 mode):
extension_dir = "/usr/lib/php5"
wrongly supposing that PHP would scan subdirectories as well…
In fact I had to add:
extension_dir = "/usr/lib/php5/20060613+lfs"
As most PHP programs use MySQL, including those in the installer scripts I’m voting to apt-get install the php5-mysql lib during virtualmin pro installation, but more importantly to correctly configure the extension_dir to the right path.
Hope the above will be useful to others and that it was the correct way to do. At least it works.
