I have recently decided to stop using Webmin via a Apache proxy for security reasons (as its treated as localhost). Now I have reverted the changes in “/etc/webmin/config” by removing them from the file.
Today i noticed that some of the links on webmin where still being prefixed with the /webmin/, if you look at the screenshot you will see that the stuff i have circled are all prefixed with /webmin/. It is only those URL’s which have this issue every other URL in webmin works fine.
For example.
/webmin/virtual-server/edit_newquotacheck.cgi
should be
How do i fix this?
Because of this prefixing which shouldn’t be happening anymore those links are inaccessible with a “Error - File not found” unless i manually remove the prefix.
Thanks,
Shane
